fZhan14
New Contributor II
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
154 REPLIES 154
AMusa2
It seems i have the same problem on a seven days old 120GB SSD
AMusa2
This is from a friend of mine. It is clear that it is a general problem.
Jose_H_Intel1
Valued Contributor II
A ratio of 2-to-1 in NAND-to-Host writes you show in the pictures is not unusual and it is not too bad.
AMusa2
I agree, 2-to-1 is OK, but as you can see in the print screen below taken a few seconds ago it keep growing. And as you can see in my friend print screen above the ratio in 4-to-1. I don't think it's OK. And from what i have seen over my research on model 520 that ratio is below 1. So, in my opinion is something wrong here . But I'm no expert and i might be wrong, that's why i am asking here.
Thanks for your support!
JChil2
Mine is even worse!
Windows 7 operating system.
ASUS G73SW Notebook
Current Status on drive:
(1) INTEL SSDSC2BW240A4
Several days ago as posted above:
Power On Hours : 250 hours
Power On Count : 98 count
Host Reads : 2127 GB
Host Writes : 642 GB
NAND Writes : 2856 GB
Today:
Power On Hours : 302 hours
Power On Count : 111 count
Host Reads : 2535 GB
Host Writes : 671 GB
NAND Writes : 3081 GB
The write amplification is increasing. now up to 4.59 ratio.
I moved the temp files and internet files to the second drive, do not use drive compression or encryption.
Normal use on a daily basis. do not download movies or photos.
I also installed the same drive as a second drive in my system for file downloads and backups and this is how it looks:
ASUS G73SW Notebook
Current Status on drive 2:
(2) INTEL SSDSC2BW240A4
Power On Hours : 117 hours
Power On Count : 34 count
Host Reads : 324 GB
Host Writes : 247 GB
NAND Writes : 236 GB
The write amplification is a 0.95 ratio.
Help
