fZhan14
New Contributor II
Hello, everyone:
The situation is as follow:
Testing condition:
Thanks for your help.
154 REPLIES 154
JChil2
I found that the Windows operating system (Win 7), Anti-Virus and anti Malware programs are always writing small files to the disk causing the high write amplification. If you work with large files it will be lower. My solution was to set up a ram disk and also use a disk caching program to reduce my write amplification. Use junction points to have the small writes from various programs to write to the ram disk, the Disk caching program reduces the other writes to the disk by discarding the old unused temp writes. Write amplification on the data disk is less than 1 and my operating system disk is now around 2. See my previous posts for what I was dealing with as far as write amplification before these changes.
These tools work well and solved my issue with write amplification.
jbenavides
Valued Contributor II
Thanks for sharing this information Jonnie; this confirms write amplification varies from system to system, and it can be reduced using external tools as well.
JChil2
I also have the same problem with the 530 Series 240GB drive, the Total Nand Writes are excessive. The drive is only about a month old, I'm afraid it wont last long at this rate.
Any updated information from INTEL.
Please help.
Windows 7 operating system.
ASUS G73SW Notebook
Current Status on drive:
(1) INTEL SSDSC2BW240A4
Model : INTEL SSDSC2BW240A4
Firmware : DC32
Serial Number : **********************
Disk Size : 240.0 GB (8.4/137.4/240.0/240.0)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 468862128
Rotation Rate : ---- (SSD)
Interface : Serial ATA
Major Version : ACS-2
Minor Version : ----
Transfer Mode : SATA/600
Power On Hours : 250 hours
Power On Count : 98 count
Host Reads : 2127 GB
Host Writes : 642 GB
NAND Writes : 2856 GB
Temparature : 38 C (100 F)
Health Status : Good (100 %)
Features : S.M.A.R.T., APM, 48bit LBA, NCQ, TRIM
APM Level : 00FEh [ON]
AAM Level : ----
Jose_H_Intel1
Please allow us more time to check on this.
Thanks.
