Intel Pro 2500 240GB SSD problem
10-09-2018 02:22 AM
Dear Support,
Intel Pro 2500 240GB SSD have a problems with read operations.
Than I have wiped it using Intel Toobox and Activa Kill disk.
After this SSD doesn't accept write operations.
I have attached screenshots with S.M.A.R.T.
Please let me know is it possible to recover this ssd to operational state or it completely dead?
Thanks in advance,
Igor
10-09-2018 11:17 AM
Hello ibutenko,
Thank you for contacting Intel® Technical Support. As we understand, you need assistance with your Intel® SSD Pro 2500 Series If we infer correctly we will appreciate if you can provide us with the following information:- The SSU logs. 1- Go to https://downloadcenter.intel.com/download/26735/ and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply.
- A screenshot of the "Disk Management" of windows showing all your HDDs and partitions.
- The SMART details.CSV file (SMART logs) from your Intel® SSD Pro 2500 Series. In the "https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/IntelSolidStateDriveToo... IntelSolidStateDriveToolboxUserGuide.pdf" section 3.2 you can find the instructions on how to get this file.
10-09-2018 02:13 PM
10-10-2018 01:25 PM
Hello ibutenko,
Thank you for your reply. We are going to be working in reviewing the information, pictures and the logs you provided, we will be contacting you back as soon as we have an update or in case that further information is required. Thank you for your patience and understanding. Best regards, Josh B.Intel® Customer Support TechnicianUnder Contract to Intel Corporation- Mark as New
10-15-2018 10:37 AM
Hello ibutenko,
Thank you for your reply and the information provided. You are going to receive an email shortly from our advance technical support department in order to further assist you. Thank you for your patience and understanding. Best regards, Josh B.Intel® Customer Support TechnicianUnder Contract to Intel Corporation
