intel 750 SSD which PCIE slot best for max performance? or does it matter?
I bought the intel 750 PCIE SSD and am wondering which slot i should plug it into? it fits every PCIE but people say my 16x pcie is best choice.
2 REPLIES 2
Rekamaj,
Thanks for posting in our community, about your question we can let you know that the SSD supports the PCIe NVMe 3.0 x4, so you can use any slot x4 or above and the performance will be the same.Please check this http://ark.intel.com/compare/86739,88744,86740 link where it gives you more details about all three HHHL SSDs.Let us know if you require any more information.NC
Rekamaj,
We are following up on this case and we would like if you require any more assistance from us.We will be waiting for your response.NC
