Intel 750 boot problem
07-13-2017 11:57 AM
Hi, I have a supermicro X10DRD-iNT which has two U.2 connectors on it.
I got two Intel 750 SSD's, 2.5" 400Gb. I can't get these to work.
If I plug both in, computer freezes at the last bit of POST, saying ready to boot...
If I plug one in (doesn't matter which one, i've ruled out faulty cables/connectors), it boots up fine.
then I'll have to hot-plug the other one once windows loaded, which half the time freezes windows.
I have managed to boot it all the way to windows with both connected twice over three days and probably hundreds of reboots.
nVME drivers installed, RST installed, SSD toolkit says they're both fine the few times i've been able to see them. updated firmware on both.
flashed BIOS to latest update, cleared CMOS. fiddled around with the UEFI settings.
supermicro support said something about the SSD's not having any option ROM. setting this to EFI or Disabled makes no difference.
i'm on windows 8.1 at the moment but also purchased a windows 10 pro license. both behave the same.
I don't have the OS on these disks, it's on a samsung evo on sata.
any thoughts?
thanks /Sam
07-18-2017 01:31 PM
hi
ehrm, you discontinued the 750's now!? ..brilliant, thanks.
anyway, i've messed around with this a heck of a lot more and it's nothing to do with power.
either it's a faulty cable, i've ordered a new one but i don't have much hope, or, judging by the number of complaints, this is all a bit hit and miss and i've ended up with crappy disks or something is conflicting in the build, in which case i'll have to replace them.
i'll keep you posted.
/S
07-18-2017 02:38 PM
Hi Thesejm,
The Intel® SSD 750 series was discontinued on April 30th, 2017. You can check the http://qdms.intel.com/dm/i.aspx/E3A4F190-F8EC-4E32-B731-24EBFD3C62DC/PCN115375-01.pdf product change notification for that.Now, about the situation, we believe as well this could also be related to a cable; However, it is hard to say since each drive works fine individually.Please keep us posted, it will be nice if Supermicro* could also check about this situation with other drives, just to confirm the two ports can handle this configuration.Regards,Nestor C- Mark as New
08-03-2017 07:01 AM
still no luck getting this to work.
here's a rundown.
I have all the latest drivers for RST and nVME.
I can't boot the machine with both drives attached, supermicro confirms both ports are meant to work at the same time.
I can boot with one drive attached.
if I hotplug the drives, one works fine, put in the second, windows gets extremely slow/becomes unresponsive.
the MB has onboard Ethernet, intel X540-AT2. when I hotplug the ssd's,(scan for new hardware in DevMan) network connection shuts down temporarily and comes back on if it's successful and windows doesn't crash. (EventViewer says MEIx64 service shuts down and sometimes RST service terminated unexpectedly)
when windows crashes, it gives a bsod with watchdog violation. hal.dll+3795 and ntoskrnl+1953af
this is from the eventviewer (.NET runtime and Application Error):
Faulting application name: IAStorDataMgrSvc.exe, version: 12.8.0.1016, time stamp: 0x51fb0c50
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x04154ca5
Faulting process id: 0x27a0
Faulting application start time: 0x01d30c5b3bc708dc
Faulting application path: C:\Program Files\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
Faulting module path: unknown
Report Id: bbf626f4-0836-4c2c-8db2-6f61abd75283
Faulting package full name:
Faulting package-relative application ID:
this is an excerpt from intelSSDTDK log-file, some 1117 error here:
any thoughts on this? I have absolutely no idea what's going on.
drive failure? they're brand new, I've never had anything on them.
15:32:05:063668 [debug] CommandPath_NVME_MSFT.cpp(107) sendCommand: Attempting to send command via IOCTL_STORAGE_QUERY_PROPERTY
15:32:05:063668 [debug] CommandPath_NVME_MSFT.cpp(239) sendDeviceIoControl: About to call DeviceIoControl (IOCTL_STORAGE_QUERY_PROPERTY)15:32:05:063668 [error] CommandPath_NVME_MSFT.cpp(300) sendDeviceIoControl: IOCTL failed via OS error: 1 = Incorrect function.15:32:05:063668 [debug] CommandPath_NVME_MSFT.cpp(547) test: Test result: False
15:32:05:063668 [debug] CommandPath_NVME_MSFT.cpp test: Exiting15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(510) getNVMECommandPath: Failed to talk via: nvme::msft15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(516) getNVMECommandPath: Failed to talk NVMe. Trying MMIO.15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(519) getNVMECommandPath: Creating and checking command path: mmio::nsg15:32:05:063668 [debug] CommandPath_MMIO.cpp(220) test: Entering15:32:05:063668 [debug] CommandPath_MMIO.cpp(80) sendCommand: Sending command: IdentifyControl Code: 2054General Purpose: 0Transfer Bytes: 409615:32:05:063668 [error] CommandPath_MMIO.cpp(169) sendCommand: IOCTL failed: 1117 = The request could not be performed because of an I/O device error.15:32:05:063668 [debug] CommandPath_MMIO.cpp(236) test: Test result: False
15:32:05:063668 [debug] CommandPath_MMIO.cpp test: Exiting15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(529) getNVMECommandPath: Failed to talk via: mmio::nsg15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(535) getNVMECommandPath: \\.\SCSI1:. Target: 0. PathId: 0. LUN: 0. has failed to talk NVMe. Moving on.15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp getNVMECommandPath: Exiting15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(442) scanNVME: Checking for remapped RST controllers on \\.\SCSI1:15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(632) getScsiAddressesOfRemappedRstControllers: Calling DeviceIoControl IOCTL_SCSI_MINIPORT (IOCTL_REMAPPORT_GET_PATHIDS_IMPLEMENTED)15:32:05:063668 [error] DeviceFinderExtension_NVME.cpp(647) getScsiAddressesOfRemappedRstControllers: Failed to call IOCTL_SCSI_MINIPORT (IOCTL_REMAPPORT_GET_PATHIDS_IMPLEMENTED). OS Error: 111715:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp scanNVME: Exiting15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(155) scan: Opening connection to \\.\SCSI2:15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(168) scan: Scanning for NVME support and devices15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(380) scanNVME: Entering15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(246) scanRSTeVMD: Entering15:32:05:063668 [info] DeviceFinderExtension_NVME.cpp(269) scanRSTeVMD: NVME_GET_NUMBER_OF_PASSTHROUGH_DISKS for RSTe passthrough failed.15:32:05:063668 [info] DeviceFinderExtension_NVME.cpp(269) scanRSTeVMD: NVME_GET_NUMBER_OF_JOURNALING_DRIVES for RSTe passthrough failed.15:32:05:063668 [info] DeviceFinderExtension_NVME.cpp(269) scanRSTeVMD: NVME_GET_NUMBER_OF_SPARE_DISKS for RSTe passthrough failed.15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp scanRSTeVMD: Exiting15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(402) scanNVME: \\.\SCSI2: is the controller for \\.\PHYSICALDRIVE315:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(453) getNVMECommandPath: Entering15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(458) getNVMECommandPath: Testing for NVMe support on \\.\SCSI2:. Target: 0. PathId: 0. LUN: 015:32:05:063668 [debug] CommandPath_NVME_NSG.cpp(53) CommandPath: Creating async engine for AER15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(462) getNVMECommandPath: Creating and checking command path: nvme::windows_debug15:32:05:063668 [debug] CommandPath_NVME_Windows_Debug.cpp(51) test: Entering15:32:05:063668 [debug] CommandPath_NVME_Windows_Debug.cpp(86) test: Calling DeviceIOControl: IOCTL_SCSI_MINIPORT (NVME_DEBUG_DRIVER_IDENTIFICATION)15:32:05:063668 [debug] CommandPath_NVME_Windows_Debug.cpp(100) test: IOCTL failed via OS Error: 1117 = The request could not be performed because of an I/O device error.15:32:05:063668 [info] CommandPath_NVME_Windows_Debug.cpp(113) test: Windows Debug NVMe test result: False
15:32:05:063668 [debug] CommandPath_NVME_Windows_Debug.cpp test: Exiting15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(473) getNVMECommandPath: Failed to talk via: nvme::windows_debug15:32:05:063668 [debug] CommandPath_NVME_NSG.cpp(53) CommandPath: Creating async engine for AER15:32:05:063668 [debug] DeviceFinderExtension_NVME.cpp(477) getNVMECommandPath: Creating and checking command path: nvme::nsg15:32:05:063668 [debug] CommandPath_NVME_NSG.cpp(613) test: Entering15:32:05:063668 [debug] CommandPath_NVME_NSG.cpp(136) sendCommand: Sending command: Identifythanks /S
08-03-2017 12:35 PM
Hi Thesejm,
Thanks for the logs provided over here. We would like to share this with our engineering department and check if there is something else from our side that can help on the resolution of this situation.
We'll be providing updates as soon as we have some.
Regards.
08-03-2017 01:00 PM
ok, thank you!
looking forward to hearing what the engineers think.
regards /S
