08-29-2015 09:43 AM
I have installed 120 Gb 530 Series SSD into barebone system based on Celeron J1900 processor. But the system did not recognized it in AHCI mode, so I had to switch to IDE one to install Windows. My question is: is there any way to force my SSD to work in AHCI mode now, after Windows (8.1 SL) is installed?
08-31-2015 01:23 PM
rockit,
What you saying may be possible but please be aware that such procedure is not supported by Intel as it implies in making changes in the registry of Windows* itself. If you want to retry a clean installation, please before you do it, make sure you update the BIOS and check with your OEM (Original Equipment Manufacturer) if they have any driver updates.
08-31-2015 01:39 PM
Thank you for the reply. But in my case it's impossible to get any support from the device manufacturer I couldn't even find out what the model of ATA controller (and it's definitely is Intel's one - PCI\VEN_8086&DEV_0F21&SUBSYS_0F218086&REV_0E) is installed on motherboard.
09-01-2015 11:06 AM
rockit,
Please bear in mind that such procedure is not supported by Intel.
09-01-2015 11:51 AM
Yes, I understand it clearly. Thank you for the warning.
BTW, (if it's possible of course) can I learn which one of Intel controllers goes under Dev_ID I mentioned above?
