02-29-2024 02:35 AM
I have P4510 15.36TB E1.L SSDs and I have used incorrect firmware on this device.
Can you please help provide the latest correct firmware for me?
[root@TServ ~]# rpm -qa |grep -i 'sst-'
sst-1.11.268-0.x86_64
[root@TServ ~]# sst show -sst
Bootloader : 0376
Capacity : 15.36 TB (15,362,991,415,296 bytes)
DevicePath : /dev/nvme1n1
DeviceStatus : Healthy
Firmware : VEV10270
FirmwareUpdateAvailable : The selected drive contains current firmware as of this tool release.
Index : 1
MaximumLBA : 30005842607
ModelNumber : INTEL SSDPEWKX153T8
NamespaceId : 1
PercentOverProvisioned : 100.00
ProductFamily : Intel SSD DC P4511 Series
SMARTEnabled : True
SectorDataSize : 512
Best Regards,
Jim Hsu
02-29-2024 10:36 AM
Hello Jim_Hsu,
You can find all the information related to SSD firmware on our website. For your drive, the latest version available is VEV10284.
Tools and instructions to perform the update are on the following web page:
Latest Firmware For Solidigm™ (Formerly Intel®) Solid State Drives.
If you need further assistance, please do not hesitate to contact us via our Support Hub . We will be happy to assist you!
Yordan
Solidigm Customer Support.
03-06-2024 02:35 AM
I have install this tool under RHEL 8.8 and run command to check disk firmware.
Is there any way can re-flash SSD firmware when using the SST tool?
Could you give me any suggestion or commands?
Best Regards,
Jim Hsu
