Intel 520 180GB Installation issue
01-21-2013 09:45 AM
01-21-2013 10:15 AM
Difficult to say what's going wrong with your install. James from Intel has an excellent video on how to install an SSD in a notebook, maybe watching it will help:
http://www.youtube.com/watch?feature=player_embedded&v=Sk12_QFTgSw&list=PLA905CA68DDBC01B9 Intel SSDs - Beyond the Box: Data Migration and Hardware Installation - YouTube
01-21-2013 03:24 PM
Brad, thanks for the link. I reviewed the information you provided. I have updated multiple desktop PCs with SSDs and all have gone smooth, no issues. That is one of the reasons I thought I would update my laptop, the desktop updates were so easy. I re-formatted the SSD drive and attempted to use the Intel Data Migration too, unfortunately this tool did not see my SSD drive. I then used the EZ Gig IV tool to migrate the data from my HDD. The copy was successful so I replaced the HDD with the SSD. Windows took over 4 minutes to boot. Whenever I attempt to open a file or start an application it takes more than 15 - 30 seconds to complete any of these tasks. I did manage to install the Intel SSD Toolbox. This application does see my SSD as an Intel SSD drive. I have run the SSD Optimizer, Quick Diagnostic Scan, System Tuner, System Information, Firmware Update and I am currently executing the Full Diagnostic Scan. Everything is much slower. I checked the Intel site to see if there were any updated drivers that I needed. This does not appear to be the issue. My gut feeling is this is some sort of bios issue, but there are not many options to change. Any advice or suggestions is appreciated...... thanks
01-21-2013 05:32 PM
Just checked the specs of your laptop, it has a 1st generation SATA1 interface while the 520 SSD has a SATA3 interface. The specs say it's backward compatible although you will only see the performance of the host.
Try putting the SSD into the laptop and do a clean install of Windows 7, preferably using a disk that has SP1. See how the drive behaves after the first boot. If the BIOS and/or the Windows installer doesn't see the drive things aren't looking hopeful.
01-22-2013 07:39 AM
Thanks for the suggestion. I may try that but I'm leaning towards building a new desktop and I may use the SSD for that build. Both of my laptops are older and won't make use of the SATA3 interface on the SSD whereas the desktop has the newer SATA3 controller. I'll update this post with how I fix the performance issue.... thanks
