02-09-2019 06:31 PM
Hello.
I have 2 Intel 535 180GB SSD. I bought another same SSD. It had DevSleep enabled, so I decided to update firmware of it. After updating, it doesn't appear in BIOS. When I short together rom mode jumper on the SSD board, it appears as sandforce {200026BB}. The data on SSD is obsolete, I would like to revive the SSD. Please help me do this.
02-14-2019 09:15 PM
02-12-2019 12:34 PM
02-12-2019 09:51 PM
02-12-2019 10:50 PM
This update bricked my SSD in the first place. But OK, I downloaded it again, but it doesn't recognize my SSD (see photo).
Check out video: https://dropmefiles.com/GxaLQ
02-13-2019 09:24 PM
02-13-2019 09:30 PM
So, basically, what you says is: if someone uses Update Tool 2.0.15 and bricks his/her SSD, it's users' fault and this is not fixable. Good to know, now I will definitely buy and recommend anything but Intel. Thanks.
