Error 26 in SSD Toolbox?
The SSD Optimizer encountered an error (26) when trying to optimize. What is error 26?
6 REPLIES 6
ASouz7
Valued Contributor
Hello richardm1,
Have you tried to update the Intel® Solid-State Drive Toolbox to the latest version? Here you can find the link to it: https://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Intel® Download Center
-What type of PC are you using? (laptop or desktop)
-What is your OS?
- How is the SSD connected this PC?
-Has this error occurred before?
  • It is a laptop on Windows 7 x64
  • The SSD is internal (SATA). It was just recently installed; this is the first time I have attempted to run SSD toolbox on this machine. It has never worked, even after a reboot.
  • The SSD used to be in a desktop machine and SSD toolbox ran OK on that system.
ASouz7
Valued Contributor
Hello richardm1,
Can you please provide the following?
1 - System make and model
2 - Firmware version of the SSD
3 - Details export from the Intel® Solid-State Drive Toolbox
4 - Copy of C:\intel\logs\intelSSDTDK.log
  • HP Elitebook 6930p
  • SSD Toolbox 3.2.3
  • Firmware 335u
  • The error in the log is [14:04:46:12] ERROR : .\Optimizer.cpp(225): Optimizer::Execute: Failed to set backup privilege
  • I am running the SSD toolbox as Administrator (right click, Run as Administrator).
