Degraded 750 - Unable to mount drive.
I have a 1.2 TB Drive that is suddenly reporting as "health is degraded. Contact support." I'm now unable to mount the device. How can I revive the device?
Cheers.
7 REPLIES 7
Here's the report from the drive:
'ID', 'Description', 'Raw', 'Normalized', 'Threshold', 'Action'
'Word', 'Description', 'Value'
0-1, PCI Vendor ID (VID), 8086
2-3, PCI Subsystem Vendor ID (SSVID), 8086
4-23, Serial Number, *****Will Provide if needed***
24-63, Model Number, INTEL SSDPEDMW012T4
64-71, Firmware Revision, 8EV10171
72, Recommended Arbitration Burst (RAB), 00
76, Multi-Interface Capabilities, 0
77, Maximum Data Transfer Size, 5
78-255, Reserved,
256-257, Optional Admin Command Support, 6
, Bit 15:3 - Reserved, 0
, Bit 2 - Support Firmware Activate Download, 1
, Bit 1 - Support Format NVM, 1
, Bit 0 - Support Security Send Receive, 0
258, Abort Command Limit, 3
259, Asynchronous Event Request Limit, 3
260, Firmware Updates, 2
, Bit 7:4 - Reserved, 0
, Bit 3:1 - Number FW Slots Support, 1
, Bit 0 - Is FW Slot Read Only, 0
261, Log Page Attributes, 2
, Bit 7:1 - Reserved, 1
, Bit 0 - Support SMART Per Namespace, 0
262, Error Log Page Entries, 3F
263, Number of Power States Support, 0
264, Admin Vendor Specific Cmd Configuration, 0
, Bit 7:1 - Reserved, 0
, Bit 0 - Admin Vendor Specific CMD Format, 0
265-511, Reserved,
512, Submission Queue Entry Size, 66
, Bit 7:4 - Maximum Entry Size, 6
, Bit 3:0 - Minimum Entry Size, 6
513, Completion Queue Entry Size, 44
, Bit 7:4 - Maximum Entry Size, 4
, Bit 3:0 - Minimum Entry Size, 4
514-515, Reserved, 0000
516-519, Number of Namespaces, 0
520-521, Optional NVM Command Support, 6
, Bit 2 - Dataset Management Command Support, 1
, Bit 1 - Write Uncorrectable Command Support, 1
, Bit 0 - Compare Command Support, 0
522-523, Fused Operation Support, 0
, Bit 15:1 - Reserved, 0
, Bit 0 - Compare and Write Fused Operation Support, 0
524, Format NVM Attributes, 7
, Bit 7:3 - Reserved, 0
, Bit 2 - cryptographic Erase Support, 1
, Bit 1 - secure Erase All Namespaces Support, 1
, Bit 0 - format All Namespaces Support, 1
525, Volatile Write Cache, 0
, Bit 0 - NVM Vendor Specific CMD Format, 0
526-527, Atomic Write Unit Normal, 0
528-529, Atomic Write Unit Power Fail, 0
530, NVM Vendor Specific Command Configuration, 0
531-2047, Reserved,
2048-2079, Power State 0 Descriptor,
, Bit 255:125 - Reserved,
, Bit 124:120 - Relative Write Latency, 0
, Bit 119:117 - Reserved,
, Bit 116:112 - Relative Write Throughput, 0
, Bit 111:109 - Reserved,
, Bit 108:104 - Relative Read Latency, 0
, Bit 103:101 - Reserved,
, Bit 100:96 - Relative Read Throughput, 0
, Bit 95:64 - Exit Latency, 0
, Bit 63:32 - Entry Latency, 0
, Bit 31:16 - Reserved,
, Bit 15:0 - Maximum Power, 9C4
3075, Stripe Size, 5 (128 KiB of user data)
3096, Current PCIe Link Speed, 3
3097, Negotiated PCIe Link Width, 4
3098, Security Capabilities, 0
3099, Security Status, 1
3100-3107, Bootloader Revision, 8B1B0131
0-7, Namespace Size, 0
8-15, Namespace Capacity, 0
16-23, Namespace Utilization, 0
24, Namespace Features, 0
, Bit 0 - Thin Provisioning Support, 0
25, Number of LBA Formats, 0
26, Formatted LBA Size, 0
, Bit 7:5 - Reserved, 0
, Bit 4 - Metadata transfer bit, 0
, Bit 0:3 - LBA Format Support, 0
27, Metadata Capabilities, 0
, Bit 7:2 - Reserved, 0
, Bit 1 - Metadata transfered as part of a separate buffer support, 0
, Bit 0 - Metadata transfered part of extended data LBA Support, 0
28, End-to-end Data Protection Capabilities, 0
, Bit 4 - Protection Info transfered as last 8 bytes of metadata Support, 0
, Bit 3 - Protection Info transfered as first 8 bytes of metadata Support, 0
, Bit 2 - Protection Type 3 Support, 0
, Bit 1 - Protection Type 2 Support, 0
, Bit 0 - Protection Type 1 Support, 0
29, End-to-end Data Protection Type Settings, 0
, Bit 3 - Protection Information Transfer, 0 (Transferred as the last eight bytes of metadata.)
, Bit 2:0 - Protection Type Information, 0 (Protection Information is not enabled)
131, LBA Format 0 Support, 0
, Bit 31:26 - Reserved,
, Bit 25:24 - Relative Performance, 0x0 (Best performance)
, Bit 23:16 - LBA Data Size, 00
, Bit 15:0 - Metadata Size, 0000
135, LBA Format 1 Support, 0
139, LBA Format 2 Support, 0
143, LBA Format 3 Support, 0
147, LBA Format 4 Support, 0
151, LBA Format 5 Support, 0
155, LBA Format 6 Support, 0
159, LBA Format 7 Support, 0
163, LBA Format 8 Support, 0
167, LBA Format 9 Support, 0
171, LBA Format 10 Support, 0
Hello HNCC,
We understand your SSD is having a health degradation and it is basically not working at the moment. We'd like to assist you with this situation; however, we need you to please get in touch with our http://www.intel.com/content/www/us/en/support/contact-support.html# @19 support department, so they can further assist you.Let us know once you contact them.Regards,NC
Hello HNCC,
We are following up and we'd like to know if you were able to contact our support department about this situation with your SSD.We'll be waiting for your response.Regards,Nestor C
Hello, Yes. I did reach out to support and am being shipped a replacement.
What concerns me the most is that there was no explanation of what was wrong, so I'm concerned the drive will die again without warning. We'll see.
Thanks for getting back to me.
