02-22-2011 04:20 PM
I installed my X25-v a week ago.
I followed the instruction and did the migration from the WD 1TB to the SSD drive.
The windows experience went from 6.1 with the wd to 5.9 with the SSD drive?
When I open the tool box I see the first drive Intel SSD 37.2 GB
Second the WDC 931.5 GB
The third G: intel 0 GB why is there a G: with zero GB
TreeSize shows it as a system Reserved (system volume information [Access is denied]
Just about everytime I run a program I get a error message I am running out of disk space.
The drive is 37.2 GB and I am useing 21 gigs total on the SSD drive.
What did I do wrong if anything and how can I fix this.
I ran the tools in the toolbox everything runs fine.
How do I get rid of the system reserved.
Thank you
03-11-2011 12:34 AM
For space saving tips have a look at post 5 in this thread: /message/115253# 115253 http://communities.intel.com/message/115253# 115253
In particular if you have a lot of RAM and use hibernation you will struggle on a 40GB drive.
I'd be inclined to do a secure ease and a new install. If the drive does not then show a significant improvement in performance something is wrong, but it will be easier to narrow it down once you have done the above.
If you do a fresh install disconnect all other drives until the installation is complete
