X25-V Encryption
<!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:1; mso-generic-font-family:roman; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:0 0 0 0 0 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} -->
Not sure where to direct this question so I thought I'd ask here. We recover data from various NAND based devices including http://www.recovermyflashdrive.com/usb-flash-drive-recovery flash drives and http://www.recovermyflashdrive.com/ssd-solid-state-drive-data-recovery solid state hard drives. I had some free time and was looking at a X25-V solid state hard drive and noticed the controller (PC29AS21BA0) appears to encrypt the data stored on the NAND memory chips, in the technical documentation I couldn't find any reference to this.
It appears to use a streaming cipher but I can't figure out what encryption method the drive is using. It also appears that if the NAND chips prematurely fail (ie: the data in specific areas become damaged beyond what the ECC algo can repair) the drive shows up with a capacity of 8MB.
Can you provide me with the contact information for someone who may be able to answer these questions?
What encryption method is used?
What is / how can I retrieve the key when recovering the data? Does the PC29AS21BA0 controller in the X25-M G2 series also encrypt the data when writing to the NAND chips?
Thanks,
Jeremy
[email protected]
1 REPLY 1
MBall5
Contributor
Hello, I would like to let you know that yes the Controller uses an algorithm to distribute the information on the NAND chips but how exactly is information that Intel® cannot disclose.
Therefore there is no method to recover the data once that the drive is damaged.
