X25-M 80GB low 4k read
03-22-2010 01:55 PM
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
03-24-2010 08:17 AM
which version of windows 7 are you using?
I'm using windows 7 ultimate and in the link I posted it says:
"The 100MB system reserved partition is only available for Windows 7 Ultimate, Windows 7 Business and Windows 7 Enterprise editions."
edit: nevertheless, like I said in the previous post, in my 2nd instalation I had only 1 partition and the results were identical
Message was edited by: lmsilva
03-24-2010 08:19 AM
I already told him to disconnect the other drives and reinstall Windows 7 with BIOS set to AHCI, which is what he must have done since he uses the msahci driver. Now, there is that 100 MB partition that I don't understand--I don't have it and he says Windows 7 put it there. I don't think he should have that 100 MB Reserved Primary Partition after installing Windows 7.
By the way, I have also got a score of 414 with AS SSD, the scores do vary a bit--so don't get too excited.
03-24-2010 08:26 AM
Ahh, now I understand. I have Windows 7 Home Edition x64.
Well, then it could be what he says about your motherboard, if he confirms that is the issue. You could try contacting Intel and see what they say.
Message was edited by: ambizytl
03-24-2010 08:35 AM
yeah, if he confirms that his last screenshot was not made using the Gigabyte GA-55A-UD4, it seems that all comes down to the Intel P55 motherboard..
03-24-2010 08:37 AM
duplicate post..
