X25-M 80GB low 4k read
03-22-2010 01:55 PM
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
03-24-2010 06:57 AM
03-24-2010 07:26 AM
Nop, I only reconnected the other drives after I made the screenshot of the benchmark.
The 100MB system reserved partition is created automatically by windows 7 during the instalation. In my 2nd instalation of windows 7 (the current is the third one), I removed this partition using method 3 on this link http://www.mydigitallife.info/2009/08/20/hack-to-remove-100-mb-system-reserved-partition-when-instal... http://www.mydigitallife.info/2009/08/20/hack-to-remove-100-mb-system-reserved-partition-when-instal... but the results were the same, around 14 MB/s..
edit: yes, I formatted the drive during the instalation of windows. In this last attempt I even used hdderase before installing
Message was edited by: lmsilva
03-24-2010 07:40 AM
I show my picture above to show that low 4k read caused by hardware/software.
Yes... I have reached good speed.
That was I do:
1. Install intel rapid storage. To bring new drivers to system. After it safe to remove rapid storage software.
2. Removed WD6400AALS drive
3. Update bios, load bios defaults
4. Set bios to AHCI
5. Restart, 2 times, Win 7 installed new drivers for AHCI and SSD. I think it is important to do this without any other HDD in system. Win 7 tunes sytem to SSD. You can also try to change SSD port. The point is to let win 7 reinstall new drivers and ssd.
6. Connect WD HDD.
03-24-2010 07:45 AM
this last screenshot was with the Gigabyte GA-55A-UD4 or the Biostar TP45i?
03-24-2010 08:12 AM
Windows 7 did not create that 100 MB partition in my install.
