03-22-2010 01:55 PM
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
03-24-2010 03:41 AM
My SSD is in the first SATA port of the motherboard (SATA_0). Read the manual of the board, ASUS P7P55D, and it doesn't mention any SATA groups, only 6 x SATA 3.0 Gb/s ports.
I did restart the computer after switching the AHCI controllers.
This is my 3rd clean install of windows 7 and did installed it with my other drives disconnected, only the DVD drive was connected. This screenshot of the benchmark was made right after the instalation with no other hard drives connected, no motherboard/chipset drivers installed and only the DVD drive and SSD connected:
The other two pictures you requested:
Thanks once more
03-24-2010 06:22 AM
Did you reconnect the other drives before testing?
I don't understand why you have that 100 MB Reserved Primary Partition--I don't have it, I have just one Partition. Did you format the drive before reinstalling Windows 7? I suggest you format the SSD in Windows 7 and don't create a second Primary Partition--let it all hang out for one partition.
03-24-2010 06:40 AM
I think low 4k read speed is 99% hardware issue. At this topic me and TS have both Intel P55 motherboard.
I have similar results as TS on my home computer. Which is: Gigabyte GA-55A-UD4. I have tried all modes and drivers, AHCI, IDE, RAID. And tried Win 7 x64, x86 and Win XP x64. All setups gives around 15 Mb/s 4k read speed. Then I connect same SSD to Biostar TP45i. And get result on screenshot
03-24-2010 06:49 AM
Your result shows BIOS not set to AHCI, so why post it? BIOS should be set to AHCI. I don't understand why you would run SSD in IDE when it is has been clearly suggested to use AHCI for best results.
I don't know about the P55 being the problem, could be, but I still don't know why he has two Primary Partitions with one 100 MB Reserved Primary Partition. I would at least like to see what happens when he has just one Partition.
03-24-2010 06:50 AM
You don't show your firmware revision in the picture.
