03-22-2010 01:55 PM
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
04-19-2010 03:20 AM
Can someone at Intel please provide a firmware update which fixes this problem?
I have a brand new MSI H57M-ED65 which used the Intel H57 chipset.
It seems rather odd that Intel makes the chipset and the SSD but I need to disable C1 and all C States and Speedstep (EIST) to get normal performance from the drive?
So there's no way to save energy and still use the drive with max performance? I thought speedstep was only supposed to slow down the processor when it is not being used. Once the drive starts chugging, shouldn't it use its maximum throughput??
Again, PLEASE INTEL, fix the SSD Bios to work properly with the p55, h55 and h57 chipsets while using the energy saving schemes!
03-29-2010 06:19 AM
So how do you change those C1E settings in BIOS?
03-29-2010 06:58 AM
You enter BIOS and look for C1E, which is listed under Advanced BIOS Features on my motherboard, and change enabled to disabled if that is what you want to do. Look in the motherboard manual for your board to see where it's listed, otherwise, scroll through the different sections.
