X25-M 80GB low 4k read
Hi all,
- system restore off
- index off
- hibernation off
thanks in advance
72 REPLIES 72
As I said, interesting. I have normal speed with C1E enabled with my motherboard. I also have a Gigabyte board, EX38-DS4
There is something wrong with your system setup. First, with new Intel driver installed, you should have iaStor as the driver listed in AS SSD, not msahci. Secondly, both you and Pavle have 420 which is lower than mine on my old funky Dual Core E8400 and Gigabyte EX38-DS4 MB. As you can see, the driver listed in my picture is iaStor.
What may make a difference is disabling the msahci driver so it doesn't load on bootup; this can be done in the registry if you are interested. Still, even with msahci loading on bootup in my system, the Intel driver is the driver for AHCI on my computer. I think it would be worth a shot for you to disable the msahci in registry.
Type regedit in the search bar and hit enter.
* This opens the Windows Registry editor. * Move to the path HKEY_LOCAL_MACHINESystemCurrentControlSetServicesMsahci * Locate the parameter [Start] on the right side and double-click it. * Change its value from 0 to 3 * Restart the computer.
I also moved to intel iaStor driver :
Yes, better benchmark results than msahci driver, but how much of a difference do you see in usage? Anyway, since it supports TRIM, I see no reason not to switch. By the way, results do vary and you may get lower scores on next run.
