01-06-2010 10:59 AM
My configuration:
OS: W7 x64 Ult
MB: Gigabyte EX58-UD3R
SSD X25-M 80GB G2 plugged on the GSATA 2 connector of MB
What I tried:
01-06-2010 12:20 PM
You should connect the Intel SSD to the first Intel SATA port and not to any GIGABYTE (=JMicron) SATA port. After having done that, you should enter the BIOS and set the Intel SATA Controllers to "AHCI" Mode.
If you still get the message "bootmgr is missing", just boot off the Win7 x64 DVD or USB Stick and let Windows Setup repair the MBR.
01-06-2010 01:14 PM
Thank you Fernando for your answer. I already tried to check AHCI in bios setup but the option "automatic repair for boot issue" doesn't repair succesfully the "bootmgr is missing" problem, so I'll try again with dos fixmbr command
01-06-2010 02:45 PM
Hello. See if the information in the following thread helps. I have an EVGA 790i mobo, and the solution was to change from the NVIDIA controller back to the "Standard" controller as in the thread below. Then my drive is seen by the tool.
/message/78383# 78383 http://communities.intel.com/message/78383
Best wishes/jim
01-06-2010 03:34 PM
Now, all is ok for my SSD . And I complete the Fernando answer by reporting that the problem of restarting after check AHCI in bios setup is caused by a Windows installation with IDE driver instead of AHCI driver. But the very simple solution is given by Microsoft Support for Vista as for Win7 here:
http://support.microsoft.com/kb/922976/en http://support.microsoft.com/kb/922976/en
or http://support.microsoft.com/kb/922976/fr http://support.microsoft.com/kb/922976/fr
for french people like me . Big thanks also to this complet FAQ about Intel SSD's (in Fr) at: http://forum.hardware.fr/hfr/Hardware/HDD/topic-unique-intel-sujet_858306_1.htm# bas http://forum.hardware.fr/hfr/Hardware/HDD/topic-unique-intel-sujet_858306_1.htm# bas
