12-03-2009 08:13 AM
And, since SSD Optimizer is part of the Intel SSD Toolbox, those of us with new G2 SSDs cannot utilize TRIM until the SSD Toolbox download is available.12-06-2009 07:41 AM
Have you updates your BIOS to the latest version?
12-06-2009 12:41 PM
Yes,
The Gigabyte has the latest BIOS. It will post with the SSD unplugged.
12-06-2009 01:02 PM
ckett,
If you were able to install win7 on the SSD, then after the installation it will not post suggest to me that you have a driver conflict.
Which drivers were installed after win7 completed the installation. Did you use Intels? Or did you use the default Microsoft drivers? Also, how did you install win7 the first time? Did you install with AHCI enabled or did you install with IDE enabled?
12-06-2009 02:40 PM
I am pretty sure I installed with AHCI enabled. I may try to do all of this over again to better track what is working and what is not. It is my understaing that if you enable AHCI in the BIOS before installing Win7 that Win7 will default to using the Microsoft AHCI driver. However, when I boot up my computer the screen before Windows loads shows Intel AHCI in the title. How do I know for sure that the Windows AHCI driver is the one to be used?
12-06-2009 03:19 PM
Go to Device manager, storage controllers, double click the one which controls your SSD, go to driver tab, click driver details. If the driver listed is msahci.sys, then you're using the default microsoft ahci driver.
