Trim function works well on Linux/Ubuntu 9.10 64-bit
11-20-2009 10:51 AM
For those waiting for an updated TRIM enabled firmware for their x25-m 80gb g2 postville:
I flashed my drive and am trimming away!
If you track the conversation from here onwards you should be all set: http://www.ocztechnologyforum.com/forum/showthread.php?t=60882&page=10
1) download hdparm 9.27
2) make, make install
3) apply the latest patch mentioned in the thread above as presented on page 10 by danekl
4) copy wiper.sh to usr/local/bin
5) run from terminal: sudo wiper.sh --commit / or sudo wiper.sh --commit /dev/sdaN (where sdaN is your ssd)
BTW, this is not real TRIM but gives the same effect. I run this each time at system start up.
Skip Windows, go Ubuntu!
11-23-2009 08:07 PM
This is exactly the output:
wiper.sh: Linux SATA SSD TRIM utility, version 2.5, by Mark Lord.
rootdev=/dev/sda1 rdev=/dev/sda1fsmode2: fsmode=read-write/: fstype=ext4freesize = 132285104 KB, reserved = 1322851 KBPreparing for online TRIM of free space on /dev/sda1 (ext4 mounted read-write at /).This will be a DRY-RUN only. Use --commit to do it for real.Creating temporary file (130962253 KB).. Syncing disks.. Simulating TRIM operations..get_trimlist=/sbin/hdparm --fibmap WIPER_TMPFILE.3818(dry-run) trimming 261924512 sectors from 4280 rangesRemoving temporary file..Syncing disks.. Done.- Mark as New
11-24-2009 04:40 AM
Sorry, being a complete noob I can't help you, I've been fiddeling for days myself to get wiper.sh to work!
I ended up registering on the OCZ form where the guys where extremely helpfull and made a few patches that were essential to get wiper to work.
But I first followed up another suggestion: use wiper 1.9 and that worked straight away!
But... before you do anything ensure your drive supports trim, flash it (with the firmware Intel tookoffline). Linux is no Windows 7 so your machine shouldn't hang. Mine didn't!
11-24-2009 05:35 AM
Thanks, blackSP. My ssd has the right firmware. I upgraded before Intel pulled it. I will try the wiper 1.9 version.
02-13-2010 01:19 AM
I upgraded my Intel G2 80GB SSD to the newest firmware ending in HD
I have hdparm 9.27 installed on my Arch Linux system
I patched the wiper.sh v2.5 to work for the Intel SSD and named it wiper-intel.sh
Now wiper-intel.sh works. I no longer get the "Input/Output Error"
I uploaded the patched wiper.sh to rapidshare here...
http://rapidshare.com/files/349948975/wiper-intel.sh
MD5sum= 90e596a399ff6660c8542bf6be1d58ce
SHA1sum= f1af639d00a671532069ccf6407a91a35bf94521
Here is the output of the last run of wiper-intel.sh on the ext4 /root partition on my Intel SSD
[XXXXX@LinuxBox ~]$ sudo ./wiper-intel.sh --commit /dev/sda2
wiper-intel.sh: Linux SATA SSD TRIM utility, version 2.5, by Mark Lord.
Preparing for online TRIM of free space on /dev/sda2 (ext4 mounted read-write at /).This operation could silently destroy your data. Are you sure (y/N)? y
Creating temporary file (45499969 KB).. Syncing disks.. Beginning TRIM operations../dev/sda:
trimming 31178749 sectors from 512 rangessucceeded/dev/sda:
trimming 31375361 sectors from 512 rangessucceeded/dev/sda:
trimming 28445834 sectors from 464 rangessucceededRemoving temporary file..Syncing disks.. Done.- Mark as New
02-18-2010 12:46 AM
I have an Intel G2 160 GB SSD. I have not been able to download the modified script from rapidshare, but from somewhere else, even though I cannot be sure of the integrity of the script then. It first seems to be OK (maximum number of displayed ranges is 512), but I'm still having the input/output errors.
1) can someone confirm that it also work on 160 GB model?
2) if so, could you indicate an alternate trustworthy download location?
Thanks!
