Still confused
05-28-2010 02:09 PM
My disk-configuration can't possibly be unusual, so I am wondering if I am stupid that doesn't understand how to upgrade the 160GB X25-M FW. Can someone look at my configuration and give me some helpful hints?
I have Windows 7 on a X25-M G2 160GB - not AHCI
Then I have two non-SSD disks in RAID (Intel Matrix Storage) for extra storage, i.e. my SSD is not in RAID.
I have heard that I have to disable my RAID even if it doesn't involve my SSD. Is that correct?
If so, at what point should I enable it again?
Are there other things to consider with this configuration?
05-31-2010 03:45 AM
have you read the read me? http://downloadmirror.intel.com/18363/eng/README_REV26.txt
06-01-2010 01:15 PM
Thanks for you answer.
My BIOS says IDE, RAID or AHCI. The readme doesn't state exactly IDE, so I don't know if it is supported. I can't use RAID, and I installed Windows 7 with IDE set before I added the last two disks setting RAID.
Should I disconnect the RAID-disks, set AHCI, do the upgrade and set RAID again? Or will that f... up my Windows7?
Or should I try the same with IDE instead of AHCI?
06-06-2010 01:46 AM
The motherboard is an ASUS P6T if that is of importance...
