SSD Toolbox: No Optimization due to " Volume Shadow Copy Service data"
12-27-2009 03:46 PM
Hi all and support!
In an other thread some users had problems running the new optimizer in the SSD Toolbox 1.2.
Me too - 😉
Running XP pro 32 bit with system recovery disabled (via ssd tweaker util) and volume shadow copy service (vssvc.exe) manually disabled.
There are no system recovery points stored. Additionally I stopped all services that are bound to the backup software Acronis True Image Home
that I have installed. Even when starting XP in secured mode (German: Abgesicherter Modus via F8 at start time) the optimizer didn't start.
Version 1.1 worked so far I could see - I didn't check the variation of access times.
Any hint or clue?
Thomas
SSD X-25M 160GB Gen2 (FW 02HD), Notebook Samsung Aura Danica, XP Home SP3 32-bit, SSD Toolbox 1.2.0
02-14-2010 02:59 PM
It' works for me too!
02-04-2010 08:10 AM
I just come up with a really simple hack without modify vssadmin.exe,
here is the video
http://www.youtube.com/watch?v=AEjccPrObOE http://www.youtube.com/watch?v=AEjccPrObOE
in text
just run cmd.exe
click title bar
select defaults
change default codepage to 437 (OEM - United States)
click ok
and you are done
02-04-2010 01:08 PM
Dear AndCycle and GSzabo!
You did a great job! Thx a lot - hopefully that the responsibles at Intel will use
your informations to fix the coming version of the toolbox.
I preferred to change my german version to the international "vssadmin.exe".
The windows service which pretends overwriting system files has to be tricked:
Deleting the german file in the DLL-Cache allowed copying the engish version
to system32 directory...
So we can state: problem fixed... 😉
wu
Thomas
02-04-2010 03:42 PM
Still not sorted 😞
Not only am I already running English (British English not American English) but I also can't change the codepage from the CMD title bar.OK I'm missing something here but what is it?
Toolbox V1.2 trim still doesn't run on my XP64 system.
02-04-2010 03:49 PM
you said you are using xp 64,
I know this have been mentioned in this thread,
but have you tried the patch mentioned in readme?
<!-- /* Font Definitions */ @font-face {font-family:Wingdings; panose-1:5 0 0 0 0 0 0 0 0 0; mso-font-charset:2; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:0 268435456 0 0 -2147483648 0;} @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} @font-face {font-family:Verdana; panose-1:2 11 6 4 3 5 4 4 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1593833729 1073750107 16 0 415 0;} @font-face {font-family:"Neo Sans Intel"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-alt:"Segoe Script"; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-format:other; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin-top:0in; margin-right:0in; margin-bottom:10.0pt; margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi; mso-fareast-language:EN-US;} a:link, span.MsoHyperlink {mso-style-priority:99; mso-style-unhide:no; mso-ansi-font-size:9.0pt; mso-bidi-font-size:9.0pt; font-family:"Verdana","sans-serif"; mso-ascii-font-family:Verdana; mso-hansi-font-family:Verdana; mso-bidi-font-family:"Times New Roman"; color:# 0860A8; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {mso-style-noshow:yes; mso-style-priority:99; color:purple; mso-themecolor:followedhyperlink; text-decoration:underline; text-underline:single;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} .MsoPapDefault {mso-style-type:export-only; margin-bottom:10.0pt; line-height:115%;} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.0in 1.0in 1.0in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} /* List Definitions */ @list l0 {mso-list-id:1018461300; mso-list-type:hybrid; mso-list-template-ids:-820628554 -60786850 67698691 67698693 67698689 67698691 67698693 67698689 67698691 67698693;} @list l0:level1 {mso-level-start-at:0; mso-level-number-format:bullet; mso-level-text:; mso-level-tab-stop:none; mso-level-number-position:left; margin-left:67.5pt; text-indent:-.25in; font-family:Symbol; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast;} ol {margin-bottom:0in;} ul {margin-bottom:0in;} -->
Known Issues
· Intel SSD Optimizer will not run on Microsoft Windows XP 64 bit or Windows Server 2003 64 bit Operating Systems
· When the Intel SSD Optimizer is run on either of the above named operating systems which do not have the Microsoft hot fix installed, the tool displays an error message stating the program has detected the presence of a Volume Shadow Copy service data, even if none is present.
WORKAROUND: The link to a Microsoft Knowledge Base article is located here: http://support.microsoft.com/kb/942589 http://support.microsoft.com/kb/942589 Follow the instructions to install the hot fix. When completed, the Intel SSD Optimizer will run correctly.
