10-16-2011 12:53 PM
I have a 120GB Intel 320 SSD. My setup is:
When I try to run the optimizer it says, "Cannot run the Intel SSD Optimizer on RAID configurations."
I don't think I have a RAID setup. Do I have an HP propriatary setup? Or could this be a problem with an Intel SSD on AMD chipset?
Thanks in advance for any help!
Brian
10-18-2011 03:45 AM
I have a similar problem on my Intel DX58SO2 motherboard. The SSD Toolbox does not state I am running RAID though. It shows that the tool is not supported for my drive and will not allow me to use it.
The problem for me was that I installed the Marvel SATA3 driver under Windows. After installing it, the SSD Toolbox refuses to allow optimize to execute.
Do you have any third-party disk drivers installed on your system?
10-18-2011 12:01 PM
Thanks, Dryne. I am not running any third party disk drivers that I know of. I'm running the system as it came stock from HP (I migrated the original HD onto my Intel SSD 120GB and have been using that ever since).
10-18-2011 05:31 PM
Try this:
Click your start button under Windows 7 followed by entering the following in the Search programs and files input box:
SystemPropertiesAdvanced.exe
On the System Properties window that appears, click the Hardware tab followed by clicking the Device Manager button.
You will see the Device Manager window appear showing a tree view of your computer name at the top with several items under. Look for the Storage controllers item in this tree view then expand it. What do you see listed under it?
10-18-2011 10:17 PM
Under Search programs and files input box: "Device Manager".
Most likely you are running AMD Drivers. If you revert to the W7 generic ACHI drivers, you will be able to run the SSD Optimizer.
