Partition Alignment neccessary?
11-11-2011 09:50 AM
I have an Intel 320 running an Windows XP and Ubuntu system in Dual-Boot with GRUB.
The first partitition starts at sector 63 ( one sectors has 512bytes) or 32256 bytes.
This is a fresh clone from a HDD and performance measurements are satifactory after
a few days of moderate usage. There are also no hangs or freezes until now.
Therefore my question:
Is a partition alignment to 4096 byte boundaries strictly neccesary or does the
SSD-controller inside the 320-models already cope with any partition offset/boundaries
without causing any extra wear and tear?
Regards,
Lophiomys
11-22-2011 05:04 AM
Thanks, I have already studied all I could find about partition alignment on the internet.
A lot of information there is either inconsistent or wrong, or simply superseeded by new technologie.
So, just to avoid a misunderstanding,
you are saying that there is no extra wear on the live span of memory cells,
if you do not partition-align an Intel 320 SSD, because the controller internally cares for proper aligment
to memory cell boundaries?
Where does the performance gain come from after the partition alignment, if the controller handles the aligment internally already?
Could you post links to the benchmarks, that you have seen? (its the internet after all)
Thanks.
12-19-2011 02:33 AM
More than 1200 hits, 3 weeks gone and
still no definite and unambigous answer to the questions in the original post.
12-20-2011 12:26 PM
Benchmarks and Discussion right here: /thread/20042 http://communities.intel.com/thread/20042
12-20-2011 01:16 PM
Yup.
In your first answer you say that "the controller handles the partition misalignment".
So external alignment should not be necessary?
As opposed in the thread, you are linking to, there is a clear advice to do manual
partition alignment. Whereby I see that the published benchmarks there, do not
show any significant improvement in speed, except for the 4k writes.(delta is 10MB/s)
Additionally this in contradiction to the timings I did on my own Intel 320 before and after alignment.
On my system the 4k-measurements did not change, but the sequential wirte values improved by
about 10MB/s after deleting some GB of data and performing partition alignment.
(As a reminder: I never had a speed problem.)
The intitial question remains open:
If the partitions are not aligned on an Intel 320, does it cause extra internal wear and tear in the long term?
