My 4k-64Thrd Read is low
Hi guys, I installed an Intel x25-m 80 Gib and everything seems to be fine.
But when comparing my results with a lot of people I always see that I'm scoring the lowest on the 4K-64 Thrd.
I run the Intel SSD Toolbox optimization but same results showed up.
What is the 4K-64Thrd? and how can I improve it?
Here's a my benchmark, Thanks.
9 REPLIES 9
I think your score might be fine. A little low but there could be a number of things affecting it. Now I ran a benchmark on mine today after not doing it for months and I'm getting a horrible score. Bios is set to achi. MS trim was working. Installed the toolbox just to try it, and running it made no difference. Any suggestions or could the drive be failing?
Your AS benchmark is showing a pciide driver. What controller are you using?
What's the controller?
Go to the control panel and select Device Manager. Look for IDE ATA/ATAPI Controllers. Select the controller and right click over it. You should see this:
