Issue with SSD Toolbox
Hi, i just installed 80GB 25-M ssd - OS - XPSP3 PC - dell e6400
When i open the drive toolbox I do not see any drives listed...i downloaded the latest toolbox, latest rapid store tech and latest bios for my laptop...
any ideas on whats going on?
6 REPLIES 6
okay..so i tried the toolbox on another machine (same machine hardware, with XP as well) and it works fine...so there is something up with this particular machine and the XP configuration?!?!
any ideas would be helpful...i checked for the .NET installs, checked bios settings, and both are same between the two laptops.
When you installed the Toolbox, did you notice that it also installed .NET Framework 2.0, which is required for the Toolbox? Check your installed programs from the Control Panel if you aren't sure.
