IRST 11.6 is bugged!
MSmit17
Don't you test your software before release it?
The 11.6 interface can't be opened, debug errors shows. All this under windows 7 ultimate 32 bits. Tested on two different pc's.
67 REPLIES 67
Hello, I currently have RST v. 11.7.0.1013 installed, everything seems to work fine except I can't access GUI. The tray icon is loaded and hangs there (Intel RST service is not running), and if you click it, the IaStorUI process briefly appears in process list, then it gets killed and WerFault activates and the following set of errors appears in Even Viewer:
1)Error 18.12.2012 21:56:45 Application Error 1000 (100)
Faulting application name: IAStorUI.exe, version: 11.7.0.1013, time stamp: 0x50aa9318
Faulting module name: ISDI2.dll, version: 11.7.0.1013, time stamp: 0x50aa92da
Exception code: 0xc0000417
Fault offset: 0x000462d0
Faulting process id: 0x116c
Faulting application start time: 0x01cddd490a452bec
Faulting application path: C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorUI.exe
Faulting module path: C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\ISDI2.dll
Report Id: 4921e679-493c-11e2-8a70-c860008a72d2
2)Error 18.12.2012 21:57:53 WMI 10 None //Not sure if this one is related, thought there is stable correlation.
Event filter with query "SELECT * FROM __InstanceModificationEvent WITHIN 60 WHERE TargetInstance ISA "Win32_Processor" AND TargetInstance.LoadPercentage > 99" could not be reactivated in namespace "//./root/CIMV2" because of error 0x80041003. Events cannot be delivered through this filter until the problem is corrected.
3)Error 18.12.2012 21:58:02 Application Error 1000 (100)
Faulting application name: IAStorDataMgrSvc.exe, version: 11.7.0.1013, time stamp: 0x50aa9310
Faulting process id: 0xf58
Faulting application start time: 0x01cddd4938f8819a
Faulting application path: C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
Report Id: 76b65a74-493c-11e2-8a70-c860008a72d2
4)Error 18.12.2012 21:58:05 Service Control Manager 7034 None
The Intel(R) Rapid Storage Technology service terminated unexpectedly. It has done this 1 time(s).
My specs: Asus P8z77 v-pro, bios v. 1708 with Intel RST OROM v. 11.0.0.1339 (loool, when you will put a new one in bios, asus?!), my system SSD is using IaStorA driver.
Your thoughts? Is is me or Intel?
MSmit17
Dude, really post your problem on asus forums too, they think there that im an isolate case.
Link my post on their forums.
Nah, i posted the entire thread there, they don't care.
What happened when I tried 11.7.0.1013.
Faulting module name: ISDI2.dll, version: 11.7.0.1013, time stamp: 0x50aa92daException code: 0xc0000417Fault offset: 0x000462d0Faulting process id: 0xf9cFaulting application start time: 0x01cdd3358ff3e7efFaulting application path: C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exeFaulting module path: C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\ISDI2.dllReport Id: cdfae71a-3f28-11e2-aa66-801f022f3d36
