IRST 11.6 is bugged!
09-17-2012 05:58 PM
Don't you test your software before release it?
The 11.6 interface can't be opened, debug errors shows. All this under windows 7 ultimate 32 bits. Tested on two different pc's.
09-20-2012 08:41 PM
09-20-2012 09:55 PM
Yes I must agree that the IRST GUI in version 11.6.0.1030PV will not start in Windows 7 Home Premium, 64 bit.
Of course, I don't have the 11.6.0.1702 OROM that is paired with this version of IRST, but who does?
Doesn't seem to be part of the latest BIOS updates for Intel Z77 mother boards, which are still on OROM 11.2.0.1527, or earlier.
09-22-2012 09:38 AM
I also have this problem but it seems to like my old P965 ICH8R setup.
/thread/31822 http://communities.intel.com/thread/31822
09-24-2012 02:04 AM
Before installing this application or requesting technical support from Intel, first contact your system manufacturer. They typically provide software which is specifically configured for your system.
And below is the disclaimer from Intel download center:
DISCLAIMER: This software is provided by Intel only for the convenience of its customers. THIS SOFTWARE IS PROVIDED "AS IS" WITH NO WARRANTIES WHATSOEVER, INCLUDING ANY WARRANTY OF MERCHANTABILITY, NON-INFRINGEMENT, FITNESS FOR ANY PARTICULAR PURPOSE, OR ANY WARRANTY OTHERWISE ARISING OUT OF ANY PROPOSAL, SPECIFICATION OR SAMPLE. This software is furnished under license and may only be used or copied in accordance with the terms of the license. The software is subject to change without notice. Intel assumes no responsibility or liability for any errors, incompatibility issues, inoperability or inaccuracies that may appear in this software.
