Intel X25-M 160 GB
Hi all,
I just got a new HP Envy 15 and an Intel X25-m 160 GB. I manually installed the SSD and cloned the original 500GB HDD. Everything was fine until I tried to update the Intel SSD firmware. I downloaded the firmware update tool and made the bootable cd. Yet when I try to update the firmware I get this:
Intel SSD is not attached or is disabled.
If you know an Intel SSD is installed and correctly connected to your system, please contact Intel Customer Support for further assistance at the following website: http://www.intel.com/ssdsupport http://www.intel.com/ssdsupport
So do you have any idea of how I can update the firmware?
10 REPLIES 10
Thanks for the reply.
I installed the latest HP ENVY bios, but as far as today the bios does not have any option to set legacy or compatibility. Are you saying that the first time you had to update your SSD by connecting it to another pc...but then every other firmware update tool worked just fine by just running the bootable cd in your pc?
