How to Fix Bad Blocks in SSD X25 160GB ?
Hey All!
Yesterday, I've experienced an NTFS BSOD.Today I had another one, this time I've got a dump file.when I analyzed it I've got :KERNEL_DATA_INPAGE_ERROR (7a)The requested page of kernel data could not be read in. Typically caused bya bad block in the paging file or disk controller error. Also seeKERNEL_STACK_INPAGE_ERROR. I've tried to run chkdsk and fix the blocks, but I'm not sure it was successful. CHKDSK is verifying files (stage 1 of 3)... 729344 file records processed.File verification completed. 1138 large file records processed. 0 bad file records processed. 2 EA records processed. 197 reparse records processed.CHKDSK is verifying indexes (stage 2 of 3)... 1018110 index entries processed.Index verification completed. 0 unindexed files scanned. 0 unindexed files recovered.CHKDSK is verifying security descriptors (stage 3 of 3)... 729344 file SDs/SIDs processed.Security descriptor verification completed. 144384 data files processed.CHKDSK is verifying Usn Journal... 37265120 USN bytes processed.Usn Journal verification completed.Windows has checked the file system and found no problems. 156185599 KB total disk space. 126836176 KB in 578548 files. 312828 KB in 144385 indexes. 0 KB in bad sectors. 838979 KB in use by the system. 65536 KB occupied by the log file. 28197616 KB available on disk. 4096 bytes in each allocation unit. 39046399 total allocation units on disk. 7049404 allocation units available on disk. I've run HDTune: HD Tune: INTEL SSDSA2M160G2GC Health ID Current Worst ThresholdData Status (03) Spin Up Time 100 100 0 0 Ok (04) Start/Stop Count 100 100 0 0 Ok (05) Reallocated Sector Count 100 100 0 3 Ok (09) Power On Hours Count 100 100 0 3384 Ok (0C) Power Cycle Count 100 100 0 1581 Ok (C0) Power Off Retract Count 100 100 0 27 Ok (E1) Load/Unload Cycle Count 200 200 0 145807 Ok (E2) Load-in time 100 100 0 2526 Ok (E3) Torque Amplification Count 100 100 0 0 Ok (E4) Power-Off Retract Cycle 100 100 0 -8120237 Ok (E8) (unknown attribute) 99 99 10 0 Ok (E9) (unknown attribute) 98 98 0 0 Ok (B8) (unknown attribute) 100 100 99 0 Ok Power On Time : 3384Health Status : Ok But when I did an health check, It found 2 damaged blocks. HD Tune: INTEL SSDSA2M160G2GC Error Scan Scanned data : 152566 MBDamaged Blocks : 0.1 %Elapsed Time : 19:06 I've downloaded the SSDToolbox from Intel site and run a full diagnostics. While the Data Integrity Scan succeeded. the Read Scan test failed. How do you recommend me to proceed? ThanksAriel
5 REPLIES 5
Russian programers made life easier already, there are two tools that can "remap" bad blocks, they are old but still working with drives less then 1,5TB.
They are Victoria and MHDD
http://translate.google.com/translate?hl=ru&sl=auto&tl=en&u=http://hdd-911.com/index.php%3Foption%3D... http://translate.google.com/translate?hl=ru&sl=auto&tl=en&u=http://hdd-911.com/index.php%3Foption%3D...
http://www.ihdd.ru/download/software/mhdd/ http://www.ihdd.ru/download/software/mhdd/ The documentation and FAQ is here http://hddguru.com/software/2005.10.02-MHDD/ http://hddguru.com/software/2005.10.02-MHDD/
Use at your own risk, disconnect all others drives, put controllers into IDE compatible mode!
Those tools can force drive to remap the bad block, they are working on the most usual magnetic hdds
You can scan (read) with remap enabled twice or even all night (LOOP) and if your realocated sector counts do not increase and no more errors, then it must be fixed. This is non destructive method for the exciting filesystem (does not matter is it NTFS or whatever else).
As for me I prefer to use Victoria for windows.
