04-05-2012 05:45 AM
04-05-2012 04:45 PM
Did you try to reinstall the program and then uninstall it? Regards. Peter
04-06-2012 12:04 AM
No work install becouse he say "A newe version of Interl(R) PROSet/Wireless Software for Bluetooth(R) Technology is already installed. Setup will no exit."
04-06-2012 10:51 AM
EliteZ - I would recommend you repost your question on the wireless forum. Here is the link /community/tech/wireless http://communities.intel.com/community/tech/wireless . I found this thread but am not sure it applies to you. http://www.intel.com/support/network/sb/CS-029916.htm http://www.intel.com/support/network/sb/CS-029916.htm Regards. Peter
04-12-2012 11:51 AM
Have you tried going into Device Manager and disabling the device , Than try uninstalling the software. Sometimes software will not uninstall when it is in use. But be sure to have the new program on your desktop ready to install.
