Does the automatic trim really work ?
11-09-2009 03:32 AM
Two weeks ago I have successfully updated the firmware of my brand new Intel X25 G2 80GB (to 02HA). I set the ICH9R to AHCI and then installed my brand new Windows 7 OS. I have checked that my ssd was using the MS AHCI driver. So according to Intel, everything was ok to make automatic trim work : 02HA firmware + MS ACHI driver + windows 7.
Two weeks after, all my softwares were installed on my ssd (10 GB are free now). I launched Crystal diskmark and I had only 30 MB/s for the "4k write". All the other tests ( 512 k read/write, sequential read/write and 4k read) were also a bit disappointed (but fortunately not as much as the 4k write).
So I launched the Intel SSD toolbox and ran the ssd optimizer (manual trim). And yes, after that, my ssd is like brand new : 70 MB for the 4k write... (the other values are also higher).
So, does the automatic trim really do its job ? How can I check that it is really active ?
11-09-2009 01:20 PM
I didnt tried it, but I just runned:
"C:\Windows\system32>fsutil behavior query disabledeletenotify"
And win replied:
DisableDeleteNotify = 0Also crystaldiskinfo says TRIM is suported (it said it wasnt before the FW update):
11-09-2009 01:41 PM
I have these options in BIOS (BIOS config is correct):
-> Options under "SATA Configuration":
- DISABLE
- COMPATIBLE
- ENHANCED
If I select ENHANCED, a new field called "Configured SATA as" shows up.
-> Options under "Configured SATA as":
- IDE
- RAID
- AHCI
So i Have ENHANCED + AHCI in BIOS.
11-09-2009 01:48 PM
"fsutil behavior query disabledeletenotify" only tells you that Win 7 is sending the trim command. It does not tell you what, if anything, is happening to the command that it sends out. It is on by default in Win 7 so regardless if you have a trim f/w or not it will still be on unless you turn it off.
I also don't think that trim is working automatically. I've now turned off the manually scheduled trim from the toolbox and once the drive has had a chance to enter the used state I will benchmark it to find out.
11-09-2009 01:51 PM
Which is the setting for controller and which is for ports? And under what settings did you flash the firmware update?
11-09-2009 11:14 AM
Interesting, does anyone know if I can still obtain a copy of the optimization software, Intel took it off of the download site and I want it.
