Will SSD stayed trimmed with Win-7 and WinXp partitions installed?
12-16-2009 11:59 PM
12-17-2009 03:05 PM
I am wondering about the same question with multiple partitioned drive, any insight would be helpful.
My current layout (Intel X25-M G2 with newest firmware)
- Windows 7 Ultimate x64 (45 gb)
- Mac OSX 10.6.2 (Snow Leopard) 115 gb
12-17-2009 08:20 PM
TRIM does not work on a HFS+ filesystem. One key point is forgotten. The "TRIM" command is filesystem agnostic,but the implementation is filesystem dependent and SSD firmware dependent. This is why the implementation of TRIM has not been standardized in Linux, Unix, or Apple's Operating system.
12-17-2009 08:13 PM
TRIM only works on the active partition. The XP partition will not be trimmed, unless you logon to your XP partition and use the Intel Toobox.
12-17-2009 10:13 PM
dbm,
This is not strictly correct and is in conflict with your post of 9:20p, below. The OP's speculation is correct under certain circumstances.
The OP has described three areas of his SSD as follows:
Here is the proposed partition layout:
* 32gb for Win-7-64-bit* 20gb for WinXp-Sp3 Pro 32-bit* Remainder of drive for shared data and applicationsWhen an NTFS file is deleted by either Win7 or XP, that file is "marked for deletion." When booted to Win7, in addition to marking a file for deletion that is deleted by the user, the OS sends trim commands associated with that file to the SSD. The trim commands cause the SSD to physically erase the blocks associated with the deleted file at an off-peak time (a time other than a write-intensive time). (Note that this process is unnecessary with an HDD because the HDD is capable of over-writing dirty physical blocks. The SSD cannot overwrite and must first erase and can only then write new data.)
XP is not trim-aware. Thus, when booted to XP, a file delete does not automatically send trim commands to the SSD to delete the corresponding dirty blocks. The salvation, though, is that "dirty" blocks are blocks associated with files that have been marked for deletion. When run, the Intel SSD Toolbox utility scavanges the file system for files marked for deletion and sends corresponding trim commands to the SSD to erase the dirty blocks. The Toolbox utility can be scheduled to run while booted to XP, Vista, or Win7.
Notice that I said "scavanges the file system." Under XP, Vista, and Win7, the "file system" for these purposes is any NTFS-formatted partition that is visible to the currently-executing OS. While executing Win7, the file system obviously includes the OP's Win7 partition. By the OP's definition, his program and data files are part of the file system when booted to either XP or Win7. If the OP assigns a drive letter to his XP partition under Win7, it too is part of the file system under both XP and Win7.
The practical answer to the OP's question is therefor "yes." The SSD can/will stay trimmed with Win7 and WinXP partitions installed. Since the OP's principal OS is Win7, he simply schedules the Intel SSD Optimizer tool to run daily at a time when he knows that he will be booted to Win7 (e.g., at 3:00a) and checkmark "apply to all SSD drives." The tool will scavange all files marked for deletion on both the Win7 and XP partitions (e.g., SSD drive C: for Win7 and SSD drive 😧 for XP) and will assure that the SSD is clean as a whistle on a daily basis. Note that this is effectively equivalent to running a non-destructive "HDDerase" each day. Once per day is the finest granularity available with the current (removed) Toolbox. Otherwise, one could schedule it to run every five minutes, given that it takes only a few seconds to run and that it only erases dirty blocks. That would be unnecessary, however, given that it takes much more than a single day of ordinary use to cause drive slow-down due to pre-erasure of dirty blocks during write operations, assuming that the drive is not almost full.
Some have had trouble with the Toolbox; thus Intel's having removed it from download. I had no problem with the firmware upgrade and have had no problems after several weeks of Toolbox use. That could be associated with my old Dell D620 laptop, which unfortunately lacks an AHCI option in the bios.
Also note that use of the Toobox causes Win7 restore points to be deleted. However, a (partial) workaround is to schedule a restore point immediately following the Toolbox scheduled run time. In any case, use the Toolbox at your own risk.
The Toolbox can likely be found with a search.
Good luck!
Ref: http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_toolbox_user_guide.pdf http://download.intel.com/support/ssdc/hpssd/sb/intel_ssd_toolbox_user_guide.pdf
Message was edited by: BruceH
