De-Frag SSD ??
07-08-2010 08:25 AM
I use PC tools for a registry cleaner , on a regular basis works great , My question was Reg. Mechanic has a feature called Registry DE-Frag, So I emailed PC Tools and asked if this would Harm my SSD , and They said NO and it was safe to run The Reg De-Frag, Has anyone else used this software on a SSD and what were the results??
07-19-2010 10:26 AM
Robert, I am glad that you are happy with PC Tools Registry Mechanic. Like mentioned in the Wikipedia article I have never read of anyone who 'ever successfully managed to measure any significant performance increase from the use of a registry cleaner.' However, I have seen friends and neighbors systems who after running one started getting bluescreens, were unable to boot, could not uninstall applications, could not apply Windows Updates, and had other problems. I have never and will never run a Reg Cleaner/Defragger on one on my systems. Why risk it if there is no measurable benefit?
07-19-2010 11:44 AM
Well like I said I guess it depends on the product, I always had good results with Reg.Mech. Besides if you can safely clean all that junk out of your sys , Why let it run around in your sys eating up resources??
07-20-2010 10:07 PM
i would suggest the recommended settings here:
http://www.intel.com/support/ssdc/hpssd/x25m/sb/CS-031542.htm
07-21-2010 08:05 AM
Your missing the point I'm talking about a Registry cleaner, I do not think companies like PC Tools or Norton would include these features if it would damage someones computer, It would leave open for Massive Law suites.
07-21-2010 08:20 AM
ichun,
You suggestion is a good one. But with every performance change you should benchmark before and after the change to verify the value of the change.
Those running Win XP can find other tips by doing a Google search for "Making XP pro SSD friendly" then clicking on the cached version of http://www.ocztechnologyforum.com/forum/showthread.php?43460-Making-XP-pro-SSD-friendly. Gen 1 drives such as Solid, core and Apex (some tweaks work well on Vertex etc also [Archive] - OCZ Forum.mht http://www.ocztechnologyforum.com/forum/showthread.php?43460-Making-XP-pro-SSD-friendly. Gen 1 drives such as Solid, core and Apex (some tweaks work well on Vertex etc also [Archive] - OCZ Forum.mht if access is blocked to the direct link.
