De-Frag SSD ??
07-08-2010 08:25 AM
I use PC tools for a registry cleaner , on a regular basis works great , My question was Reg. Mechanic has a feature called Registry DE-Frag, So I emailed PC Tools and asked if this would Harm my SSD , and They said NO and it was safe to run The Reg De-Frag, Has anyone else used this software on a SSD and what were the results??
07-08-2010 11:54 AM
Nope i haven't as i use the trim that is supplied with the ssd. Ran it once after installing the ssd and now it does it at idle automatically.
07-08-2010 12:58 PM
The product I'm talking about is Registry Mechanic, which works very well as keeping registry errors clean , which everyone should use, the part of the program I was reffering to is the registry DEfrag, it's not a hard drive DEfrager it just works on the registry. If you would like to try it PC Tools has a free download to try I have it on all 5 of my computers.
07-19-2010 06:23 AM
Over the years, many people have asked me to help them fix their systems after running a Registry Cleaner/Defragger. Unfortunately, usually the only thing that can be done is to restore from a backup or reinstall Windows. Anyone considering using one should read this BEFORE installing it. http://en.wikipedia.org/wiki/Registry_cleaner http://en.wikipedia.org/wiki/Registry_cleaner .
07-19-2010 09:57 AM
James , I have been using PC Tools Registry Mechanic for years and I have it on all fo my machines ( 7 ) , To date have never had any adverse effects, I am not sure what brand of software you are Refering to , I know some Reg. cleaners are not much more than snake Oil , But Reg. Mech. Works great for me. I contacted PC Tools and asked if it was OK to use on a SSD and said it was OK I just was asking if anyone else has had any experince doing it.When I said 5 machines I forgot my two notebooks.
