Bug after firmware update 2CV102M3
Hi! After update my SSD the line 09 "Power-On Hours Count" in SMART don't work. Has stopped on value 357 and doesn't change. All other lines work. Why the such has occurred? My configuration:
Asus P8P67 Pro
Intel X25-M SATA2 SSD (SSDSA2MH080G2R5) 80GbWestern Digital WD1001FALS SATA2 HDD 1000GbOptiarc DVD RW AD-7263S
Microsoft Windows 7 Professional x64 SP1 and last Intel RST driver
I tried to connect the SSD to other ports SATA2 and SATA3, but nothing has changed. How can I fix it? Thanx!
22 REPLIES 22
I have found in my laptop "Intel ® Rapid Storage"is only a "Intel ® Matrix Storage Console".
It's the same thing?
Yes, they are the same thing. The Intel Matrix Storage was renamed to Intel Rapid Storage: http://www.intel.com/support/chipsets/imsm/sb/cs-020649.htm http://www.intel.com/support/chipsets/imsm/sb/cs-020649.htm
Thank you for your help!
after removing the "Intel Matrix Storage", SMART began counting the hours.
