Bug after firmware update 2CV102M3
02-09-2011 04:11 AM
Hi! After update my SSD the line 09 "Power-On Hours Count" in SMART don't work. Has stopped on value 357 and doesn't change. All other lines work. Why the such has occurred? My configuration:
Asus P8P67 Pro
Intel X25-M SATA2 SSD (SSDSA2MH080G2R5) 80GbWestern Digital WD1001FALS SATA2 HDD 1000GbOptiarc DVD RW AD-7263SMicrosoft Windows 7 Professional x64 SP1 and last Intel RST driver
I tried to connect the SSD to other ports SATA2 and SATA3, but nothing has changed. How can I fix it? Thanx!
02-15-2011 12:42 AM
Yes. This is strange. Today on the Russian forum overclockers.ru another guy had the same bug. Uninstall the driver Intel RST fix it.
02-11-2011 01:24 AM
My two G2 80GB are reading this, one above 357, one below, as they should, so... this firmware was supposed to improve SMART reporting. Mine are fine.
02-11-2011 01:49 AM
I am not alone with this problem:
http://forum.asus.ru/memberlist.php?mode=viewprofile&u=113623&sid=2cd09ebf9aadabef0ecb4179406eecc8 MagicBolls wrote:
У меня мать P8P67 и Intel X25-M G2. У меня точно такая же проблема в S.M.A.R.T., пункт 09 - Power-On Haurs Count остановился и не меняется! Не важно в какой порт подключен накопитель SATA2 или SATA3.
http://forum.asus.ru/viewtopic.php?f=1&t=73905 http://forum.asus.ru/viewtopic.php?f=1&t=73905
Translate:
"My motherboard P8P67 and Intel X25-M G2. I have exactly the same problem in the SMART, para 09 - Power-On Haurs Count stopped and does not change! No matter what the port is connected SATA2 drive or SATA3."
02-15-2011 07:28 AM
Hi!
Also, after a firmware update my SSD the line 09 "Power-On Hours Count" in SMART don't work. Has stopped on value 16 and doesn't change. All other lines work. Why the such has occurred? My computer:Notebook Packard Bell EasyNote LJ75-JO-101RU
Intel Core i5 430m
Intel SSDSA2MJ080G2C1
Microsoft Windows 7 Home Premium x64
Thanks in advance for your help!
PS poor understanding of English
02-15-2011 10:06 AM
The issue seems to be with the SATA drivers. If you require this SMART field, uninstalling your Intel RST driver seems to resolve the issue and displays the updated Power-On Hours Count value.
