07-09-2011 09:23 AM
Hello Everyone,
I was recently given this drive as a gift to replace a recently crashed ide harddrive. I wasn't planning on upgrading anything else about my computer at this time, which is an AMD Athlon 64 and I'm running Windows XP Pro. I did some research beforehand and slipstreamed SP3 on my install disk and did my installation which went off without a hitch. I now have some concerns. Just to clarify, it's the 2.5 inch, 80 GB model.
All the research I've done, points to being unable to have TRIM support. On top of that, after installing the Intel SSD Toolbox, It says that it can not run it's Optimizer on my drive. Further research states that drive performance will inevitably degrade over time without one of these things to, for lack or knowledge of r a better term, clean up the drive.
I gather if I upgrade to Windows 7, it will just work out of the box due to it's included TRIM support and it's own AHCI driver. That and with an Intel CPU, I could use Intels Rapid Storage Tech.
Are there any other options for me with my current configuration? Must I break down and do some manner of upgrade? Am I worried about nothing possibly?
07-10-2011 06:45 PM
what's the error message when you run the optimizer in windows XP?
07-10-2011 06:59 PM
07-19-2011 07:05 AM
Bumping this up, wondering if there is anyone that is aware of anything I can do, or am I doomed to have my drive's performance decrease?
Also, is there any more information I can get on the new firmware I've heard rumored?
07-19-2011 09:10 AM
Did you already update Mobo BIOS, check for latest drivers, and check that the SSD has the latest firmware?
