320 / 600 GB in Proliant DL380/G7 - shows as overheating
Just installed 5 of these in a RAID configuration on a test server. Working perfectly, except:
The server is reporting that the drives are overheating (they're not). It appears that possibly I can turn OFF DIPM on these drives and the SMART info will be reported correctly.
How do I do that?
FYI, running windows 2008 r2
Thanks,
Rob
46 REPLIES 46
Will it solve the problem if adding a Intel RAID controller?
This is aN HP error.
We use Non intel SSD and get the same issue.
Same issue here with Intel 510 and 320 series.
I will watch this thread for any solution in the near future
I am the OP on this. I recently upgraded this box's BIOS, as well as some other items. I am no longer getting twice daily alerts that the drives are overheating. I have not yet been brave enough to turn back on the function where the box shuts down if it detects the overheating.
The BIOS I installed was 2011.05.05 (6 Jul 2011)
I also updated the array controller to 5.06, and updated some other miscellaneous stuff.
It is possible that HP has fixed this.
Rob
I'm glad to hear that HP has probably stepped up to the plate and addressed the problem, since truly it is within their BIOS/firmwares. However, it would be good to know what piece of the puzzle fixed the problem for you -- was it the system BIOS upgrade, the storage/array firmware upgrade, or "other miscellaneous stuff" which did it? I'm certain other ProLiant owners will want to know.
However, I also look forward to Intel (hopefully) removing advertisement of SCT tables in their SSDs. A firmware update (for the SSDs) should fix that as well.
