320 / 600 GB in Proliant DL380/G7 - shows as overheating
04-25-2011 09:25 AM
Just installed 5 of these in a RAID configuration on a test server. Working perfectly, except:
The server is reporting that the drives are overheating (they're not). It appears that possibly I can turn OFF DIPM on these drives and the SMART info will be reported correctly.
How do I do that?
FYI, running windows 2008 r2
Thanks,
Rob
05-06-2011 08:53 AM
Thanks!
05-06-2011 11:56 AM
Funny thing is.... I have a procurement order for DL380/G7 myself at work!
05-11-2011 12:36 AM
Same problem here. Has lodge a case with Intel support center. Still waiting for feedback.
05-12-2011 09:04 AM
How do you lodge a case with Intel Support?
Thanks,
Rob
05-16-2011 12:05 PM
Same problem here!!
Tested in a HP dl380 g7 performance model whit
1. INTEL 510 SERIES 2.5" 120GB SSD SATA/600 MLC 34NM
2. INTEL 320 SERIES 2.5" 120GB SSD SATA/300 MLC 25NM
3. INTEL 320 SERIES 2.5" 160GB SSD SATA/300 MLC 25NM
The all say overheated, and the server makes a terminal shutdown
The logs say 250 degrees Celsius in disk bay (That's quiet hoot)
Seems that it's the G3 model that doesn't work in HP dl 380 g7 servers
G2 models works perfectly in all my HP dl 380 g7 server
But the G2 are really difficult to find in the market today, only G3 in the shops now a days
