SSDSA2BW16G3H, 8MB "bug", and impossibility to SET_MAX_ADDRESS
PMatt1
Hi everyone,
this SSD has been struck by the 8MB "bug"/behaviour, I'm desperately looking for a way to recover as much data as possible
(therefore, I guess that the security erase procedure is not the best fit for the problem).
It is currently at firmware level 4PC10362 that - iirc - is the latest available from the Intel site for this family (and the update tool says it's already updated).
I tried to run hdparm -N /dev/sda (that actually queries the SSD for the current and max possible address) and I get a reasonable response: 16384/nnnnnnnnn (that is: currently set to 16Kblocks, that is, 8MBs, and the maximum value matches the maximum capacity).
unfortunately, if I try to run hdparm -N nnnnnnnnnn /dev/sda (temporary setting) or hdparm -N pnnnnnnnnnn /dev/sda (permanent setting), even with lower block counts,
hdparm says that SET_MAX_ADDRESS is failing for "input/output error"
I tried to also run the unofficial HDAT2 bootable iso but it appears that it cannot remount itself and make the commands actually available "or something", I guess that anyway it cannot do any magic itself and would resort to SET_MAX_ADDRESS or the like.
any suggestions?
thanks a lot!
1 REPLY 1
Jose_H_Intel1
Valued Contributor II
Hi prm, I am sorry for this inconvenience.
In this case we can only suggest taking the drive to a data recovery service. We are unable to guarantee that the data will be recovered but by contacting a company that is Intel partner, such as the ones linked below, you can be sure the Intel® SSD will keep its original warranty.
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
