SSD Intel seri 520 180Gb
ATrin
Hi you,
My ssd intel seri 520 180Gb but i check capacity it 144gb.
You can see at attach photos.
12 REPLIES 12
AP16
Contributor
Please make report in https://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Download Intel® Solid-State Drive Toolbox , save it to file and attach to post, we need to see full SMART log.
ATrin
I can't attach file log Smart ssd ?
ATrin
I take photo on screen SMART Details. You can check help me.
Thank you very much.
jbenavides
Valued Contributor II
Hello ngocan84,
Checking the SMART Details from the SSD, it is working correctly. The difference in the reported size does not seem to be an issue in the SSD.
As I mentioned before, Intel® SSD's have a overprovisioned space to be used for additional features and enhanced performance, this space is not available to the user. This space can be modified with 3rd party tools to increase overprovisioning or to match a specific drive size. In this case, it seems this was modified in your drive in the past, causing the usable drive size to be 144 GB.
In this case we advise you to contact the Place of Purchase, or the previous owner of the drive since these types of changes are not supported by Intel.
