ssd e5400s slow write speed?
APrep
my seq read speed is above 540mbps all the time but my seq write speed starts at approximately 400mbps and goes down pretty fast, why? i get lik 180-150-200 write speed in benchmarks
7 REPLIES 7
APrep
Yes, i have one more question: how do i proceed to reinstall my windows? I just have to do a normal format or i need to use secure erase?
Hello dehLord,
A secure erase is recommended in this case. However, since this is your current boot device, Windows* will not allow you to wipe the SSD.If you can connect it to a different system or boot from a different drive, you can use Microsoft DiskPart* to secure erase the SSD as shown https://www.intel.com/content/www/us/en/support/articles/000022179/memory-and-storage.html here. If this is not an option, you may proceed with a fresh OS installation.Please bear in mind that if you're planning to keep using the Intel® SSD E 5400s Series as your boot drive, the results might not vary from the current installation.Best regards,Eugenio F.
APrep
I'm aware of that! Thanks a lot for your response!
