P3700 wear info
01-28-2016 05:16 AM
i neet to monitor wearout info of my drives.
with my X25-E and S3700 i simply check SMART values like Media_Wearout_Indicator, Power_On_Hours and Host_Writes_32MiB
now with P3700 the closest i can find is "Wear Leveling Count" and "Timed Workload - Media Wear"
no info about how many hours the drive is at work and how many bytes have been written.
i'm using latest ssd toolbox and datacenter tool (isdct show -sensor -intelssd)
where did you hide that two indicators?
and also what's the difference between those two wear indicators? which one should i watch for?
01-28-2016 04:09 PM
ISRV,
We are going to check this for you and get back to you shortly.
01-28-2016 11:58 PM
i run this:
isdct dump -intelssd 0 datatype=nvmelog logid=202
and got this:
- CVFT5045008H400BGN.F4 -
Description: NAND Bytes Written
Normalized: 100
Raw: 0x20B
- CVFT5045008H400BGN.F5 -
Description: Host Bytes Written
Normalized: 100
Raw: 0x6
how to translate this?
what is nand and host bytes written?
and also which one to watch for:
Description: Wear Leveling Count
Normalized: 100
Raw: 0x100020001
- CVFT5045008H400BGN.E2 -
Description: Timed Workload - Media Wear
Normalized: 100
Raw: 0xFFFF
but still no info about how many hours online
02-03-2016 01:36 PM
Hello ISRV,
The SMART Attributes of the Intel® SSD DC P3700 and other Intel® NVMe* SSD's may be different than those of SATA SSD's.
The Normalized value of the Wear Leveling Count decrements from 100 to 0 as the blocks of the drive are written to/erased. This behaves similar to the Media Wearout Indicator of other drives.
In your case, it still shows 100, which means the average erase cycles of the NAND chips is still minimum in comparison to the rated/maximum number of erase/programming cycles.
Timed Workload is present in the SMART attributes of the P3700 and behaves pretty much like it does in other SSD's.
For more information about this, you can check the following documents:
http://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-dc-p3700-spec... Intel® SSD DC P3700 Series - Product Specification
02-03-2016 11:52 PM
so "Wear Leveling Count" and "Timed Workload - Media Wear" are just the same?
"Normalized" both 100 currently, but "Raw" are different - 0x100020001 and 0xFFFF
ok, but what about how many mb/gb/tb written and how many hours the drive is in use.
how to check those values?
i've discovered "NAND Bytes Written" and "Host Bytes Written", but don't know what exactly they mean.
again, there's normalized and raw values. but how to understand those i don't know.
maybe there's other interesting commands to isdct.exe ?
