P3608 encryption
DEmby
Can somebody help with the encryption for the P3608 PCIe (NVME) SSD.
If you can point me to the information that would be helpful,
1. I need to know how it works? does Intel supply a SW we have to load to get it to work?
2. Will it work with any OS? We want to use Linux OS
3. How does it manage the "Keys"?
Thanks in advance
Doug
8 REPLIES 8
Cheetah,
We would like to get the proper documentation for you regarding this request, please allow us to make a research and we will get back to you.
DEmby
Thank you!
I did find the following document but it appears to be old.
it-management-wde-ssd-amt-encryption-paper.pdf
ASouz7
Valued Contributor
Cheetah,
Thank you for inquiry, we are going to check this further in order to provide you an accurate answer.
Cheetah,
For this drive, we can let you know the following: The drive comes with AES 256 bit Hardware Encryption and the main configuration is actually done through BIOS. You can check this video to verify how to enable it and use it: https://www.youtube.com/watch?v=DV5zuDF6MIw PROTECT YOUR DATA! Use an Intel SSD with Full Disk Encryption NCIX Tech Tips - YouTube
Let us know if you need something else.
