03-05-2019 10:26 AM
I have a P3600 SSD firmware updated from 8DV1MD32 and to 8DV1ND38. After firmware updated to this version, it can't switch LBAF by using Linux nvme format command and it stuck on LBAF4. How can I solve this problem? Thanks!
03-29-2019 05:36 AM
Hi Santiago,
Thank you for the reply, I just ask this problem in Lenovo's forum. This thread can be closed.
03-07-2019 09:31 PM
03-27-2019 04:35 AM
I bought this SSD from China internet auction site and use in Taiwan.
I don't know which OEM to contact. Thanks!
03-27-2019 10:34 PM
Hi Mac,
Thank you for contacting Intel® SSD Support.
According with the information you provided on SSUs and S.M.A.R.T.S., your Intel® drive is an OEM product from LENOVO*; therefore, we kindly ask you to refer the Firmware issue, directly to Lenovo*/IBM*.
Intel® provides generic versions of hardware, software and drivers; OEM's may have altered features, or incorporated customizations, or other changes, such as custom Firmware.
In this case, if you are experiencing issues with, or have questions about your computer system, the system manufacturer is the best source of support.
Please let us know if you might need further assistance after contacting OEM.
Have a nice day.
Best Regards;
Santiago A.
03-29-2019 05:36 AM
Hi Santiago,
03-12-2019 04:29 PM
