02-21-2019 10:26 AM
I'm trying to passthrough (kvm/qemu vfio-pci passthrough) an Intel 660P 2TB drive. This fails the sanity check with the following error:
Error starting domain: internal error: qemu unexpectedly closed the monitor: 2019-02-21 10:08:25.261+0000: Domain id=1 is tainted: host-cpu
2019-02-21T10:08:28.947450Z qemu-system-x86_64: -device vfio-pci,host=0a:00.0,id=hostdev5,bus=pci.7,addr=0x0: vfio error: 0000:0a:00.0: failed to add PCI capability 0x11[0x50]@0xb0: table & pba overlap, or they don't fit in BARs, or don't align
Traceback (most recent call last):
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 75, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 111, in tmpcb
callback(*args, **kwargs)
File "/usr/share/virt-manager/virtManager/libvirtobject.py", line 66, in newfn
ret = fn(self, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/domain.py", line 1420, in startup
self._backend.create()
File "/usr/lib64/python3.7/site-packages/libvirt.py", line 1080, in create
if ret == -1: raise libvirtError ('virDomainCreate() failed', dom=self)
libvirt.libvirtError: internal error: qemu unexpectedly closed the monitor: 2019-02-21 10:08:25.261+0000: Domain id=1 is tainted: host-cpu
After reading about the issue here: https://patchwork.kernel.org/patch/10707761/
It seems to me that this could be fixed with a firmware update.
Is this something that is being looked at, at the moment?
Best regards.
04-24-2019 09:28 PM
Hi MLill,
Greetings from Intel® SSD Support Group.
Please accept our apologies for our belated reply, we needed to investigate about your inquiry; today, we can share the following details with you:
We have reached our business unit (BU) and according to BU updates, we were not able to replicate the issue that you are seeing. It will be extremely helpful, if you can provide a log for the issue (lspci -vvv).
On the other hand, it seems that a workaround has been applied based on the information available here: https://bugzilla.kernel.org/show_bug.cgi?id=202055 you might want to take a look on this website.
Looking forward to hearing from you.
Have a nice day.
Santiago A.
Third Party Content: Web Sites and Materials may contain user or third party submitted content; such content is not reviewed, approved or endorsed by Intel and is provided solely as a convenience to our customers and users. Under no circumstances will Intel be liable in any way for any third party submitted or provided content, including, but not limited to, any errors or omissions, or damages of any kind. ANY MATERIAL DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE USE OF THE MATERIALS IS DONE AT YOUR OWN DISCRETION AND RISK AND THAT YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR COMPUTER SYSTEM OR OTHER DEVICE OR LOSS OF DATA THAT RESULTS FROM THE DOWNLOAD OF ANY SUCH MATERIAL. By your use you agree that you must evaluate, and bear all risks associated with, the use of any third party content, including any reliance on the accuracy, completeness, or usefulness of such content. All postings and use of the Web Sites or Material are subject to these Terms of Use and any other program and site specific terms.
02-22-2019 12:36 AM
02-22-2019 01:59 PM
Here is the output from the script: https://hastebin.com/asicatirot (also attaced as .txt file, but hastebin is more convenient).
The problem is: QEMU can't initialize the nvme drive for passthrough due to bugged firmware, as per the kernel mail discussion linked. I am wondering if this is getting fixed, so that I can use the disk with PCI-passthrough.
CPU is i9-7960x with 64GB DDR4. Operating system is Fedora 29 with all the latest patches.
Running OS off Samsung 960 Pro nvme, and using pci-passthrough with another Samsung 960 (no problems with Samsungs). As soon as I add the Intel 660p to the VM config, the VM fails to start.
02-22-2019 05:55 PM
04-24-2019 09:28 PM
Hi MLill,
Have a nice day.
Santiago A.
