08-28-2013 08:20 AM
Any ideas on what to do?Clarification:
07-10-2014 03:12 PM
Also - I shipped a 530 120gb drive to Portwell via priority overnight shipping this afternoon to see if they can determine if it is a BIOS issue.
07-10-2014 10:08 PM
Hi Patriot_Ram,
Have Portwell check for support for the ATA DevSleep feature. That is one of the major feature changes we introduced with the 530 drives.
Let us know what you find out.
07-22-2014 12:20 PM
Hi Patriotram,
Just checking to see if you received my private message or if you have heard anything back from Portwell.
Thanks.
07-22-2014 03:31 PM
I just checked and haven't received a follow-up from them on that question. If you send me your e-mail address, I can add you to the thread with them and the PC manufacturer.
Thanks,
David
07-23-2014 10:27 AM
Thanks David. Look for a private message from me.
