08-28-2013 08:20 AM
Any ideas on what to do?Clarification:
12-20-2013 12:53 PM
My issue must be different, the new firmware did not resolve my issue. My shuttle PC will wont detect these drives, I have two and neither of them work. It seems that if i have a different brand of drive plugged in I get better results. Not sure if this is Shuttles issue or Intel's but I know that the Samsung drives work so I am returning 5 of these and just ordered the Samsungs.
12-20-2013 02:18 PM
I am happy to report that the new firmware fixed the problem on HP 2570p with F.44 BIOS. Warm restart is now working perfectly.
Go Intel !
12-20-2013 03:09 PM
Recently bought 240GB Intel 530 SSD for my Late 2011 Macbook 13. That was a complete failure -
2-3 minutes long boot, constant 5-10 second freezes / beachballing, disk missing on reboot.
Luckily I found this thread, and have been watching it for a while.
After applying DC32 boot now takes 20 second and seems it fixed reboot issue, too. Still i experience minor 1-2 second freezes.
Anyway, thank you guys for all of your help! Keep up good work.
I will post later after several days of testing.
12-20-2013 10:33 PM
Issue resolved on HP elitebook 8470p.
Thank you!!
Just a bit advice here, for this kind of issues in the future, maybe you can inform the customer support team and keep them updated on the progress of the engineering team? I have contacted the customer support and they suggested changing boot order, resetting bios, reinstalling OS, contacting HP (HP suggested me to do a disk check which would take hours, reinstalling OS and replace the SSD for a new one). After all this, my issue was still not solved and a lot of trouble was caused until I find this thread, then I told both customer support from intel and HP that I have identified the issue and I will just wait for the firmware update.
12-21-2013 01:52 AM
Dear sirs,
The problem is with SSD solved after installing new software and firmware provided by you. Reboot process is working.
Thank you.
HP ProBook 4540s
Andriy
